[ANSYS Meshing] Advice for meshing a complex boolean domain
Old   December 3, 2018, 10:40
Default Advice for meshing a complex boolean domain
Nick Thomas
nick.l.thomas is on a distinguished road
I am working on meshing the fluid domain of airflow over a complex geometry. I did this by creating a Boolean to extract the solid from the domain. I'm having trouble getting a good mesh by any automatic methods. I cannot share the geometry but it is essentially a large, hollow fiberglass body with many brackets and supports on the outside. I have simplified the geometry as much as I can. My main problem is that I have a lot of faces (150+), and some are very thin (1mm thick) with respect to the overall size of the device (2m x .5m x 1.5m). I have tried the auto-inflation method plus some others without much luck. What options, if any, do I have to effectively mesh this geometry without going into meshing each face/edge individually?
nick.l.thomas is offline   Reply With Quote
Old   December 29, 2018, 06:23
Default Named Selections
Oscar Ulises Espinosa
OscarEspinosa is on a distinguished road
You should try naming various faces. Here is a link with a video and there they explain with more detail.
https://confluence.cornell.edu/displ...rt+1%29+-+Mesh
OscarEspinosa is offline   Reply With Quote
boolean, complex, geometry, meshing, thin
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
Default domain jaho CFX 5 February 16, 2014 01:00
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 04:07
[Other] Meshing advice for complex domains gregorv OpenFOAM Meshing & Mesh Conversion 9 September 10, 2008 02:51
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 08:04
