November 7, 2018, 13:06 |
inflation
ibrahim jaafar
hi
i have been trying to use inflation around a simple uav , but the inflation is disappearing at the top end of the vertical stabilizer and creating some weird gap at the connection between the body and V-stab (image included) , and i am getting the following warning: Inflation created stairstep mesh at some locations. Need help solving this problem -i've tried to set maximum angle to 180 but no luck -the body and the vertical stabilizer are two separate bodies - inflation setting : first layer height : 0.3 mm maximum layers : 20 growth rate :0.2 |
May 3, 2020, 22:43 |
I see there are many overlap mesh? how does it happen?
#2 | |
Rep Power: 9 |
ansys, error, fluent, inflation, mesh |
Boundary Layer - Inflation Layer | dlkadk | FLUENT | 0 | September 16, 2017 12:11 |
[ANSYS Meshing] 3D Inflation mesh on an airfoil | kennyboy | ANSYS Meshing & Geometry | 1 | April 26, 2017 04:12 |
[ANSYS Meshing] Inflation Layers Being Finicky | Markua | ANSYS Meshing & Geometry | 12 | April 28, 2015 08:11 |
Fluent diverges when using inflation layers | ziggo | FLUENT | 4 | August 9, 2013 13:11 |
Large Valve Flow Analysis - Inflation Problem | sercan85 | ANSYS Meshing & Geometry | 2 | June 1, 2010 15:02 |
