[ICEM] Corner mesh overlapping when refine spacing down to 3.0E-6 |
Wencan Wu
Rep Power: 0 ![]() |
Hello, I have a trouble when I want to refine my mesh spacing to 3.0E-6.
As you can see in these pictures, the mesh that is near the corner of two intersected surfaces overlaps(those colored solid mesh are poor-quality mesh). The problem only occurs when I refine the first spacing to 5.0E-6 or less,while everything is ok when the spacing is 1.0E-5 or larger. I have tried to split the block to make the mesh smooth, but in vain. Any one has an idea about what's wrong with it? Thanks Thanks for your help!! |
Gert-Jan
Rep Power: 27 ![]() |
Where are your pictures?
overlapping element, structured mesh |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
