[ANSYS Meshing] Transition from o-type to unstructured back to o-type mesh
Old   November 6, 2018, 15:51
Default Transition from o-type to unstructured back to o-type mesh
Tencho
supvato is on a distinguished road
Hello, everyone.
I am trying to run a 2D simulation of flow over a circular patch of cylinders (basically a circular tube bundle) as shown in the figure (https://imgur.com/s9udiTm). The Reynolds of the small cylinders will have a range Re=73 to 1,132 depending on the diameter and the free stream velocity.
I am not very knowledgeable in CFD, so please bear with me. I have read that for simulating flow around cylinder, the best type of mesh is the o-type. Unfortunately, because of how the small cylinders are structured, I've found it difficult to apply mesh blocking, so I was wondering if it was possible to do an o-mesh over each small cylinder, have an unstructured mesh between the small cylinders, and then transition back to an o-type mesh outside of the circular patch. If this is possible, would you mind giving me a brief explanation of how to do it or a pointer to where this info can be found?
Using this type of mesh is not something I'm set on, so I am open to any other suggestions that you think could work.
Thanks in advance for any help.
supvato is offline   Reply With Quote
meshing, meshing a cilinder, o-mesh
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 03:41
Too high omega and k values in vortex flow simulation thomas. OpenFOAM Running, Solving & CFD 9 March 30, 2016 07:45
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
