[ANSYS Meshing] sweep meshing issue
Old   November 3, 2018, 07:47
Default sweep meshing issue
Asdrubale is on a distinguished road
I am trying to generate a mesh usig a sweep method, so I splitted the body in spaceclaim. Now if i go to workbench the bodies are seen as sweepable, but the meshes are not connected in the nodes. Instead if, in spaceclaim, I move the bodies to new component and select merge in the share topology section, when i turn to workbench they are no longer seen as sweepable bodies.
So how can I generate the mesh so that the bodies are connected in the mesh nodes?
Asdrubale is offline   Reply With Quote
#mesh #sweep #topology
[ANSYS Meshing] how to fix meshing fail due to sweep mode controls on simple multiphase flow sim oberstar ANSYS Meshing & Geometry 1 September 28, 2017 09:34
Guidance needed regarding the Meshing issue sidharth9426 STAR-CCM+ 5 November 9, 2015 12:56
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[ICEM] Pipe 90 elbow joint meshing issue sihaqqi ANSYS Meshing & Geometry 25 April 17, 2015 05:59
[ANSYS Meshing] Unwanted bias while meshing a tube with sweep and inflation rasko ANSYS Meshing & Geometry 7 July 23, 2012 11:31
