[ANSYS Meshing] 'Stop' button on ANSYS Mesher dialog box |
November 1, 2018, 21:22 |
Harrivin
Rep Power: 10 |
I'm using ANSYS Structural R17.2 and I noticed that the ANSYS Workbench Mesh Status dialog box does not have the 'Stop' button to kill the meshing process. The 'Stop' button is present on my friend's PC and there's a bigger dialog box too.
It doesn't matter much when there's only 1 part being meshed, I can kill the mesher using Task Manager. But when I'm meshing several parts, killing the AnsMeshingServer.exe processes becomes tedious. Anyone knows if there's a setting to enable the 'Stop' button or to make the dialog box bigger? I can't drag it at the edges like other Windows dialog boxes. |
December 7, 2018, 07:58 |
This worked well for me
Michele G,
I had the same problem, and just like you I find it very annoying. I read that someone solved it by editing an XML file in some ANSYS subfolder, but I solved it with a simple tool in a very easy way . The tool is called 'ResizableEnable'. It is a lightweigth program (only few KBs), you don't have to install it, you just have to start the EXE, it does not require administrative privileges. This is the link to the program page: http://www.digitallis.co.uk/pc/downloads.html Direct link to download: http://www.digitallis.co.uk/pc/downl...sizeEnable.zip This tool allows you to resize any window, even the ones that does not allow resizing (like Mesh Status window in ANSYS). Once you have started the tool, try to build a mesh (in order to show the Mesh Status window). Then simply put the mouse pointer in the lower-right corner of the window, and then resize it. The stop button will magically appear! Have a nice day! Michele |
December 13, 2018, 21:08 |
Worked perfectly!
Harrivin
Rep Power: 10 |
Thanks Michele. That hack did the trick. Appreciate the help.
mechanical, mesher, stop program |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Calculation stop with ansys fluent windows 8 | jb pouillard | FLUENT | 3 | September 22, 2015 03:35 |
FSI doesnt stop if i click stop button | peterputer | CFX | 7 | November 20, 2012 15:56 |
