[ICEM] How to convert a 3D mesh to 2D
Old   October 22, 2018, 04:31
Default How to convert a 3D mesh to 2D
Grigory
Easyeight is on a distinguished road
Hi all!
My case is as follows.
I have a previously created 3D mesh of a wing-fuselage body with some sweet meshing strategies. For my part of the research, I only need a 2D mesh of a wing section with those strategies from the 3D mesh.
Is there a possibility to do some kind of conversion or projection/slicing of a 3D mesh to a plane?
I saw a somewhat similar topic opened but there were no answers given, hope I'll be luckier.
Thanks in advance!
Easyeight is offline   Reply With Quote
Old   October 22, 2018, 04:38
Gert-Jan
Gert-Jan will become famous soon enough
Where do you need it for? Fluent or CFX? Or something else?
Gert-Jan is offline   Reply With Quote
Old   October 22, 2018, 04:40
Grigory
The 3D mesh is in ICEM, so I need it in ICEM and the to a Fluent solver.
Old   October 22, 2018, 04:57
Gert-Jan
If your wing intersects with a symmetry plane, then just visualise that plane and export this 2D mesh to fluent. Make sure that you tick the 2D icon upon export. (It might help to first save only the visible mesh to a separate project).
If the wing does not intersect with a symmetry plane, you have to create a new mesh. What you can do is to create a surface in your volume that intersects your wing. Then mesh this as an internal surface (see Part Mesh Setup). After meshing, only visualise this surface and export it in 2D to fluent. Make sure you don't put inflation (prisms) on this surface.
Old   October 26, 2018, 03:59
Grigory
Thanks for a reply!
I've tried what you said, but the surface I created doesn't seem to be meshed.
Am I right, that the strategy you suggested doesn't work for "Pre-Mesh->Convert to Unstruct" method? For me, it seems that I should set all the parameters for the new surface in Part Setup menu because only then it meshes the new surface.
Looks like I'm missing something or lack some skills.
I'm looking forward for your help and thanks in advance!
Old   October 26, 2018, 04:15
Gert-Jan
Aha. You are creating a hex-mesh. That make things different, and beyond my experience. But it is possible. That is for sure.
Maybe you could search the help for meshing 'thin surfaces" or 'internal surfaces" using blocking structure.......
3dto2d, icem
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ANSYS Meshing] Convert a Nastran mesh (.bdf) to Fluent mesh (.msh) dynlevirus ANSYS Meshing & Geometry 1 August 27, 2012 05:06
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
