[ICEM] No tri2tet mesh generated using Quick (Delaunay) Method
Old   September 23, 2018, 23:22
Default No tri2tet mesh generated using Quick (Delaunay) Method
deemoleina is on a distinguished road
Unable to perform a volume mesh using quick (delaunay) method. The main error reading as follows:
Error: tri2tet terminated prematurely
No tri2tet mesh generated!
Here are the main aspects of my domain.
-The cylindrical length of my domain is 9 times the length of my rocket.
-I originally performed a tetra/mixed mesh using the robust (octree) method.
-I then proceeded to delete the volume elements, leaving only the surface mesh around the rocket body.
-Smoothed out global elements iterating with Laplace smoothing on edge length.
-Created two density boxes extending from the base of the rocket. The first density box was the same length and width as the rocket, while the second is about 6 times the length, and twice as thick.
Does anybody know what may be causing this?
deemoleina is offline   Reply With Quote
Old   September 24, 2018, 08:12
Sebastian Engel
bluebase will become famous soon enough
did you check, whether you have enough memory on your computer?
Is you work directory writeable?
You may find some help in the following threads:
icem cfd tetra meshing error
surface mesh merging problem
ICEM meshing - Tips from forum - Collection
bluebase is offline   Reply With Quote
(delaunay), delaunay, tri2tet
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 09:40
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ANSYS Meshing] How to refine mesh in ANSYS 14 like CFX MESH Method in ANSYS 12 nsakib520 ANSYS Meshing & Geometry 0 October 5, 2012 02:34
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
