[ANSYS Meshing] Parallel Meshing in ANSYS
Old   September 18, 2018, 23:44
Question Parallel Meshing in ANSYS
Mike
MikeBravo is on a distinguished road
I have a large (~100M Element) multizone mesh to create, and have access to an HPC to generate it, but it is taking 48+ hours. When I try to create the mesh, no matter how many nodes and cores I'm using, it will only use 1-2 cores out of 28+ and only 20-30 GB of 128+ GB of RAM.
I have tried using parallel licensing, setting number of CPUs for meshing, but the mesher still won't utilize any more resources.
It is a single body part, so I'm not sure how it would do it, but I am looking for any help in accelerating the meshing with the HPC resources available.
Thanks in advance!
MikeBravo is offline   Reply With Quote
Old   September 24, 2018, 06:19
Sebastian
ba2ti is on a distinguished road
Hi MikeBravo
As far as I know, parallel mehsing only works for different bodies.
For example: 1 body --> 1 core, 3 bodies --> 3 cores
ba2ti is offline   Reply With Quote
meshing, meshing advice, parallel computing
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 Touré ANSYS Meshing & Geometry 2 September 26, 2017 06:41
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 11:28
2d meshing in ansys meshing syler3321 ANSYS Meshing & Geometry 10 November 1, 2012 21:42
Parallel Meshing in ANSYS 13 makkks ANSYS Meshing & Geometry 1 September 5, 2011 13:34
