[ANSYS Meshing] Why is it always the inflation layer has poor element quality |
September 18, 2018, 08:24 |
Rep Power: 14 |
Hi
I am doing a turbine simulation and I am using inflation layer around the blade walls First layer thickness first layer height 1.5e-2 mm Maximum layers of 30 Growth rate of 1.5 When I use this way I am getting bad element quality around the blades. Everytime if I check the element quality the bad one is around the inflation layer. So can someone tell me why this issue is always there ? Kindly let me know. The skewness is less than 0.6 overall. I dont know what I could do to improve in this mesh.. Image is attached. |
October 1, 2018, 17:03 |
Rep Power: 9 |
I too would like to know how to solve, I have same issue on my turbine.
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 21:05 |
[snappyHexMesh] Adding layer 3d wing (y+=1) | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 4 | November 10, 2017 01:56 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
[ANSYS Meshing] Cut cell meshing - inflation layer | Lucy13 | ANSYS Meshing & Geometry | 1 | November 23, 2015 07:17 |
[ANSYS Meshing] Inflation layer thickness based on y+ | ziggo | ANSYS Meshing & Geometry | 1 | July 29, 2013 16:17 |
