[ICEM] Pre-mesh sizing not following edge parameter |
August 29, 2018, 09:37 |
Simon
I've run into a problem creating my mesh. For some reason the pre-mesh calculated doesn't follow the edge parameters I've specified. In the attached image the sizing parameters are in red, and the generated pre-mesh in green. Can anyone shed some light on what might be happening, there are no conflicting sizing rules that I can see. Thanks |
edge sizing, icem, parameters |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
