[DesignModeler] How can I create two different fluid zone and Interface?
Old   August 22, 2018, 04:10
Default How can I create two different fluid zone and Interface?
Ghoomanjan is on a distinguished road
Hello dear friends. I am hopeful you are doing well every time in you life. I am dealing hard with a simulation in ANSYS-FLUENT. I created the model in DM of ANSYS. The model consists of two co-axis cylinders. The internal cylinder is rotating and the outer cylinder is fixed. The internal body is a little bit more complex to be called a cylinder. The volume that I need to study it is just between these two bodies. When I subtract the internal body from the outer cylinder; just a single zone is remained and for defining MRF in FLUENT I can not define interfaces. The geometry of the model is attached to this question. I do know where I should define the interfaces, too. Exactly on the internal body?
in summary:
How can I create two different fluid zone?
Where should I define the interface?
Your help is appreciated
Alireza Kiyani
Ghoomanjan is offline   Reply With Quote
ansys, design modeller, fluid zone, interface, mrf
[Resolved] GPU on Fluent Daveo643 FLUENT 4 March 7, 2018 09:02
[ANSYS Meshing] Interface between solid zone and fluid zone oozcan ANSYS Meshing & Geometry 2 August 3, 2016 12:51
Error in solution using "Grid Interface" agustinvo FLUENT 4 January 20, 2015 13:03
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
