[ANSYS Meshing] How Fluent calculates layers in First layer thickness
Old   August 10, 2018, 10:02
Default How Fluent calculates layers in First layer thickness
South Yorkshire
asking is on a distinguished road
I am performing a boundary layer mesh around a circumference. I selected the Inflation option with the following parameters:
Method: First layer thickness.
First layer size: 0.01 mm
Max. number of layers: 40
Growth rate: 1.2
I realised that, depending on the number of elements that the circumference is divided, that extent of the inflation layer changes. For example, if I divided my circumference into 60 or 120 elements, the inflation layers extent radially 43 mm and 19 mm respectively. Maybe it has something to do with the aspect ratio of the first layers.
Anyone knows how fluent calculates the layers in this methods?
Thanks,
asking is offline   Reply With Quote
fluent, inflation layer, meshing
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 04:22
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] proble of creating layers with snappyHexMesh comingdaytime OpenFOAM Meshing & Mesh Conversion 3 May 24, 2018 07:18
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
