[BladeModeler] BladeModeler/BladeGen in Linux environment |
July 17, 2018, 13:16 |
Prakhar
Rep Power: 13 |
Dear all,
I am working on an project where I create my blade design using bladegen, modify it using BladeBatch.exe for optimization, then use turbogrid to mesh the geometry and subsequently cfx to run the simulation. I have done this workflow successfully on windows batch mode. Now, in order to reduce the computational time I want to do the same workflow on Linux RHEL 7 cluster. I know that bladegen is not supported on Linux. However, is there any other way I can do the same on Linux using the command line operations? Any help or suggestions would be appreciated! Regards Prakhar |
November 9, 2020, 15:05 |
ANSYS optimization using Bladegen and Turbogrid
Joao Mattos
Rep Power: 6 |
Hello Prak,
I´ve read your post on Ansys optimization using Bladegen and turbogrid, and I´ve been trying to work on a similar project. I´m very new to this windows batch mode, do you have any resources where I can learn about it? Basically, I want to create an automated procedure to achieve a specific performance from turbomachinery. It's a type of pump, where I perform the CFD simulation using CFX, then I get a result. Then I change the pump diameter for example and get another result, so I want to do it iteratively until a reach the required result. |
ansys 18.1, bladegen, blademodeler, linux, optimization |
Problem loading UDF in Linux environment | hjan23 | FLUENT | 0 | December 15, 2017 05:09 |
Cannot configure OpenFOAM environment variable in CAE Linux 2011 | TommiPLaiho | OpenFOAM Installation | 9 | October 15, 2013 09:44 |
icem cfd ai environment 11.0, laptop keyboard problem, linux | pertupd | Hardware | 3 | October 3, 2011 09:27 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 17:49 |
Environment variable in linux | xinzhiyu2008 | STAR-CCM+ | 0 | September 8, 2010 07:08 |
