[ANSYS Meshing] Export mesh as fluent msh by using script |
anonymos
Rep Power: 16 ![]() |
I want to export mesh by using workbench script in batch mode without using mesh.edit(). it opens ansys meshing in interactive mode. i cant use sendto command to export fluent mesh in batch mode when i turn off interactive mode editing. On the other hand, when i use mesh.export(FilePath=.....), the output is .meshdat format that is not consistent with fluent. Please help. Thank you. |
ansys workbench, export, meshing, scripting |
[Other] ANSYS to Fluent mesh export in ASCII format | johannes | ANSYS Meshing & Geometry | 64 | October 19, 2021 20:13 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[ICEM] export hexa mesh to fluent | Wieland | ANSYS Meshing & Geometry | 37 | January 23, 2013 03:27 |
[ICEM] Export refined mesh to fluent | Heleen | ANSYS Meshing & Geometry | 8 | March 26, 2012 08:33 |
BC in export from hyper mesh to fluent | hamid sharif | Main CFD Forum | 0 | November 30, 2011 13:20 |
