[ICEM] Hybrid mesh with conformal interface and matching boundary layer expansion
Old   July 4, 2018, 15:02
Default Hybrid mesh with conformal interface and matching boundary layer expansion
James Gross
jgross is on a distinguished road
Hi everyone,
I would like to create a hybrid mesh of a volute geometry, with the extended pipe fully structured and the spiral unstructured. Furthermore, I would like the regions to be conformal and with prism layer expansions from the surface mesh of both regions.
Using some past posts and tips( merge meshes between hexa and prism and https://drive.google.com/file/d/0ByILTpTdfh_ednBqTXBQT3pQMjQ/view ), I have managed to get a conformal surface mesh and prism layer expansion.
The surface mesh looks like this:
I had to delete the interface between the two regions in order to get the prism layer to behave as I would expect. The prism layer expansion looks like this:
Both of the previous links state that I simply need to use Delauney to generate the rest of the volume mesh, however it does not work for me. Namely, the structured region is filled with tets:
I have also tried to merge the resulting mesh with the structured block from before, both before and after using Delauney to fill the rest of the volume, but neither have worked.
Does anyone have any tips or guidance as to how I can create this hybrid mesh with a conformal interface and prism boundary layers in both regions?
If you need the files to help, please just ask and I will happily message them to you.
Regards,
James
jgross is offline   Reply With Quote
Old   February 5, 2019, 14:07
Hilton
HBetta is on a distinguished road
Hi James,
did you manage to solve this problem? I'm in a situation similar to yours.
HBetta is offline   Reply With Quote
[ANSYS Meshing] Mesh Matching at interface between two parts bharath n ANSYS Meshing & Geometry 12 March 12, 2018 04:29
[ICEM] Hybrid Mesh Interface Node Matching abhi.jam22 ANSYS Meshing & Geometry 1 June 27, 2017 01:08
Hybrid Mesh Contour Confusion abhi.jam22 FLUENT 6 June 11, 2017 18:32
[TurboGrid] Turbogrid matching rotor stator interface mesh Jack001 ANSYS Meshing & Geometry 2 July 31, 2016 18:32
How to create matching mesh zones so that periodic boundary can be created in Fluent cgoodale1 STAR-CCM+ 3 February 29, 2016 13:34
