[ANSYS Meshing] Unable to generate mesh after face inflation
Old   July 3, 2018, 11:05
Default Unable to generate mesh after face inflation
Constantine_Akr
/Constantine/ is on a distinguished road
Hello there,
After using the inflation tool for one of the geometry faces, the mesh could not be generated and three errors appeared under the messages window (.png file attached). Why is this happening? How could I use the inflation tool properly for the inlet and outlet faces of my fluid geometry domain?
I am working on an FSI model and I am not experienced so any help would be appreciated.
For the workbench file follow the link:
https://www.dropbox.com/s/oonk87eein...bstr.wbpj?dl=0
The part I am trying to mesh is under the fluid section of the project and not under the structural.
Thank you in advance!
/Constantine/ is offline   Reply With Quote
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[ANSYS Meshing] Inflation on common Face using cutcell mesh foamcfd ANSYS Meshing & Geometry 0 July 31, 2012 09:20
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
