[ANSYS Meshing] Error in Meshing of narrow surfaces
Old   June 21, 2018, 17:48
Default Error in Meshing of narrow surfaces
Aja
aja1345 is on a distinguished road
I am simulating a spherical grooved bearing….e.g. A bearing that has spiral grooves on the ball. Please see the following figures.
There is a kind of lubricant between ball and cup, so as to prevent metal-to-metal contact (Full film lubrication theory). The dimension of groove and gap between ball and cup are in (mm) and (micron). For example, Value of groove depth is equal to 0.006 mm.
Also, you can see this Thread for more guide.
Now in Ansys meshig, when I tried to mesh, I got following error. I want to mesh be structure.
In third picture is explained about narrow surface. What do these errors happen? I am grateful that guide me in this case.
Thanks.
aja1345 is offline   Reply With Quote
Old   June 21, 2018, 22:02
Aja
I increase number of cell in edges and change dropped option to kept option in mesh method. Now, the error is only third picture.
NURBS surfaces on a wing frossi CFX 5 February 5, 2017 16:27
[snappyHexMesh] gaps for close surfaces- meshing with sHM jango OpenFOAM Meshing & Mesh Conversion 0 November 28, 2016 03:10
[GAMBIT] how do meshing surfaces like volume zogholme ANSYS Meshing & Geometry 2 September 4, 2016 04:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 04:01
