June 21, 2018, 11:11 |
ICEM wind tunnel sign panel mesh
Stan
Rep Power: 8 |
I am trying to simulate a sign panel in a wind tunnel to find ways to reduce the wind load on the panel. My geometry includes a sign panel with holes in it. My problem is when I am in ICEM and I mesh, It meshes the entire signs and tries to eliminate the holes. My process is as follows: 1 - In auto-CAD I create the model with the enclosure and then subtract the sign panel from the enclosure so it is one model. 2 - I import into ICEM as a faceted STL > repair geometry > proceed to name the surfaces (inlet, outlet, walls, sign panel etc.) 3. - Generate body two point centroid (air click on sign and inlet) (sign click on two corners of the sign) 4 - When I go to mesh, it is a tetra mesh and everything looks good aside from the sign panel being completley meshed and not meshing around the holes. I have tried the ANSYS workbench through design modeler and the meshing within workbench but it does not yield accurate results. How can I mesh the sign to where it meshes around the holes in the sign. Or if there is a better way to mesh the entire system anything works as this is my first time using ICEM. I attached screen shots of what I have been getting Thank you. Last edited by tigerdroppings; June 21, 2018 at 18:53. |
June 22, 2018, 04:49 |
Stuart
Rep Power: 26 |
Isn't that because the mesh size at the hole is greater than the hole diameter? So how do you expect the hole curvature to be captured? Use a smaller mesh sizing locally at the sign holes (e.g. a local edge sizing).
June 29, 2018, 16:57 |
Stan
Rep Power: 8 |
Under what tab would this be under in ICEM. Thank you for your help this meshing is giving me alot of trouble.
June 30, 2018, 05:15 |
Stuart
Rep Power: 26 |
You can use the Mesh / Global Mesh Size / Curvature Based Refinement or you can assign a local mesh sizing using Mesh / Curve Mesh Setup. It is useful to put such features into a Part and give it a useful name.
July 23, 2018, 14:23 |
Stan
Rep Power: 8 |
Thanks for your help I was able to get it to work. Is there an easy way to a grid independence study for the mesh?
July 30, 2018, 14:28 |
grid independence
Nam
Rep Power: 8 |
Assuming that you have a coarse mesh,
Change the global scale factor from 1 to .5 and so on, leave everything else the same |
fluent, icem, mesh, meshing, wind tunnel |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 10:43 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 11:06 |
mesh generation for wind tunnel | Waleedooo | Mesh Generation & Pre-Processing | 11 | March 19, 2013 19:36 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
