[ANSYS Meshing] problem in meshing of Aerofoil shaped obstacles in plane channel.
Old   June 20, 2018, 03:58
Default problem in meshing of Aerofoil shaped obstacles in plane channel.
lohith
lohith is on a distinguished road
Hii everyone,
I am facing problem in meshing. My geometry is a plane channel (consists of three zones) having the square cross-section and having aerofoil shaped obstacles at a particular distance. I used edge sizing, multi-zone meshing, face sizing but nothing worked. Every time it shows an error. Finally, I turned on Assembly meshing and meshing was successful. As u can see in the image that I had a fine mesh around the obstacles but I had barely 7 elements on the wall surface and my element count is around 12 lakhs.
Can anyone tell me how can I improve my mesh quality with less no of elements and Is mapped face meshing possible?
All suggestions are welcome and thanks in advance.
lohith is offline   Reply With Quote
[ICEM] Meshing Problem ? Leifheit ANSYS Meshing & Geometry 3 December 4, 2014 19:09
[Other] Meshing Layers over Aerofoil poloding-along OpenFOAM Meshing & Mesh Conversion 5 April 4, 2014 11:41
[Workbench] High Cambered Aerofoil Meshing Problem (Workbench) elebelly ANSYS Meshing & Geometry 11 February 16, 2014 11:04
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
