[ANSYS Meshing] Difficulty in mesh upload to ansys fluent |
June 16, 2018, 11:34 |
Ayodele Adeyemi
Rep Power: 8 |
Dear CFD Coleagues,
I generated unstructured mesh in ANSYS ICEM and output to ANSYS FLUENT but unable to read it in ANSYS FLUENT. I already set my boundary condition in ICEM also. I am simulating internal air flow. Below is the response when reading the mesh. I need help and would grateful for any support. 155975 nodes. 823071 tetrahedral cells, zone 25. 1614820 triangular interior faces, zone 26. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. 13294 triangular pressure-far-field faces, zone 28. 4611 triangular pressure-outlet faces, zone 29. 1709 triangular jump faces, zone 30. 1669 triangular jump faces, zone 31. 3330 triangular mass-flow-inlet faces, zone 32. 3333 triangular mass-flow-inlet faces, zone 33. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. Warning: Invalid face type 1. Skipping. 13372 triangular interior faces, zone 36. 4109 triangular pressure-outlet faces, zone 37. Building... mesh auto partitioning mesh by Metis (fast), distributing mesh parts..., faces..., nodes..., cells..., Warning: Inappropriate zone type (jump) for one-sided face zone 30. Changing to wall. Warning: Inappropriate zone type (jump) for one-sided face zone 31. Changing to wall. Warning: Inappropriate zone type (interior) for one-sided face zone 36. Changing to wall. Clearing partially read grid. Error: Failed in Fill_Domain. 1: Cell is missing face: Cell 326, zone 25, at location (-6.05335e+00, 5.24068e-01, -1.54165e+00). Error at Node 1: Build Grid: Aborted due to critical error. 2: Cell is missing face: Cell 108, zone 25, at location (-5.38603e+00, 1.13051e+00, -5.12406e+00). Error at Node 2: Build Grid: Aborted due to critical error. Note: It is possible that this case or mesh file needs to be first processed by the serial solver. To do this, please read file into the serial solver and then save it. Next, read saved file into the parallel solver. 0: Cell is missing face: Cell 11, zone 25, at location (-1.06646e+00, -7.42024e-01, -1.63180e+00). Error at Node 0: Build Grid: Aborted due to critical error. Warning: Inappropriate zone type (jump) for one-sided face zone 30. Changing to wall. Warning: Inappropriate zone type (jump) for one-sided face zone 31. Changing to wall. MPI Application rank 0 exited before MPI_Finalize() with status -1 Warning: Inappropriate zone type (interior) for one-sided face zone 36. The fl process could not be started. Interrupting... Done. > Interrupting... Done. > Interrupting... Done. |
June 17, 2018, 03:02 |
Tom David
Rep Power: 9 |
I had similar problem in the past,
Have you used the "check mesh" within Icem? Do you have any periodicity within your mesh? Do you have different volumes within your mesh? are they connected in a conformal way? Are you sure that you have also created a volume mesh? |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Importing 2D separated Hybrid mesh from PointWise to Ansys Fluent | Masoud.A1 | Pointwise & Gridgen | 6 | July 8, 2017 09:23 |
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces | Hamid.de | Pointwise & Gridgen | 4 | November 9, 2016 11:20 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
