[ICEM] Error: busy called re-entrantly
Old   June 14, 2018, 08:54
Default Error: busy called re-entrantly
Brandon
kepler123 is on a distinguished road
It's been two days since I began using ICEM CFD to mesh an airfoil in 3 dimensions, so basically, I'm meshing a wing with a O mesh. I've watched a few videos by Simon and many others and have read quite a few posts on the same. However, when I try to do stuff myself, sometimes I come across an error dialogue box that says error: busy called re-entrantly as seen in this image.
I notice that this happens when I am working on split edge. I have no clue what the exact reason for the error is, because I can go back and do the exact same thing again with no error. My main problem (other than figuring out when this error occurs) is the fact that I cannot close this dialogue box without closing ICEM-CFD. Do any of you know how I can close this error box without having to restart the software and begin working all over again from the last saved point?
I looked it up online and there is absolutely no post with this error message on any website. So I'm either missing something very obvious or I'm doing something wrong.
P.S: Some time I can close the box with one click on the Ok button, other times I cannot. Most of the times I cannot. I can't say what the underlying reason for the error is when I can close this box, as I don't understand when the error shows in the first place.
kepler123 is offline   Reply With Quote
Old   June 15, 2018, 05:05
Brandon
Update: When I close ICEM-CFD it gives me the option to save the file, I went ahead and did that and it works out fine, all I need to do is restart the program to get rid of this error. Not the best solution, but it's a solution.
Earlier I didn't risk saving on close as I assumed any discrepancies caused by the error would also be saved, but I was wrong.
Would still love to know what causes this error and how the dialogue could be closed, if at all.
error analysis, icem 18.1
How is the turbulence model called in openfoam? hz283 OpenFOAM 4 December 13, 2024 19:56
[blockMesh] Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For d tobimorak OpenFOAM Meshing & Mesh Conversion 5 October 4, 2016 15:07
terminate called after throwing an instance of 'int' b614910 SU2 10 July 27, 2014 23:16
understanding how turbulence models are called romant OpenFOAM Programming & Development 0 March 21, 2012 10:22
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 06:49
