[ANSYS Meshing] Error: degenerate to an invalid element |
Bhupinder Singh Sanghera
Rep Power: 8 ![]() |
I am trying to simulate the transonic flow around an NACA 64A10 airfoil for an assignment. For this, I have one coarser mesh (y plus between 20 and 200) and one refined mesh (y plus below 1). I use the SST turbulence model. The coarser mesh seems to work. After that, I try to change the exponential spacing (exp2 function) to a value of 1.5e-6 at the wing surface which is a guess to obtain a y plus distribution below 1. However, when I open CFX pre in the workbench for the new y plus distribution, I get an error saying: 'There was a problem importing the mesh from the requested file. The importing process reported the following problem: Hexahedral Element 18036 will degenerate to an invalid element: NodeIDs: 28651, 28531, 28532, 28652, 28651, 36587, 36588, 28652' I have been trying to fix this error for a while but did not manage yet. Help is much appreciated. Thanks. |
#2 | |
Daniel
I'm having exactly the same problem as you right now. I believe you were also working on AE4202? Did you eventually manage to fix the problem? |
Daniel
I found a solution just now. In the "Import Mesh" window, under "Advanced Options" select "Ignore Invalid Degenerate Elements". I don't know what this actually means tbh but I finally managed to import my mesh and my simulation converged nicely and the results make sense, so that's nice!
ansys, degenerate, meshing, y plus |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 9, 2019 00:50 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
parallel simulations - error message: "OPT_ITERATIONS: invalid option name" | v8areu | SU2 | 5 | July 23, 2015 03:57 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
