[ANSYS Meshing] Not able to rectify this meshing problem ?
Old   June 8, 2018, 09:50
Default Not able to rectify this meshing problem ?
sooraj546 is on a distinguished road
The size of the entire geometry is about 2.7 m dia but the inlet tubes are of 5.5 mm dia only i and not able to mesh it properly .
Even though
orthogonal 0.85
skewness 0.24 are coming.
Due to the odd surface of the tubes shown below the temp developed are causing problems. I want it to be meshed without any deformation in surface without compromising the no of elements much. kindly help me out with this
sooraj546 is offline   Reply With Quote
Old   June 11, 2018, 03:47
siw
Stuart
siw will become famous soon enough
The mesh is too coarse on those tubes. Use a finer mesh size locally. Also do you need to model near wall gradients? Thus, requiring inflation layers.
siw is offline   Reply With Quote
Old   June 12, 2018, 01:39
Thanks a lot for that reply, it really helped me a lot.
Now i have refined it to such an extend that the inlet tubes looks ok more structured but i need to confirm with an expert if its really ok.
I have attached the figures with the , Kindly have a look at it.
orthogonal quality is 0.82
skewness 0.294
which i think is ok for such a complicated diagram.......what do u think sir? I have attached the meshing techs which i have used with this reply too. Kindly help me out............
thanks i advance for the reply
Old   June 12, 2018, 09:20
siw
Stuart
If fluid is flowing along those tubes then there are not many elements to capture the physics. But you have not said anything about the simulation in order to determine an appropriate mesh. If you can run a preliminary simulation and see what your results are, then you can determine if the mesh is suitable or not and you can make the required changes.
Old   June 12, 2018, 09:32
Sir,
Those are fuel inlet tubes, fuel is sprayed with constant velocity to the furnace through them. I dnt have to capture any velocity change along the tube that's why i meshed it like that , but i have a problem with the simulation result.
In the velocity profile obtained using this mesh fig.11 on the left side (attached) i am not getting a prominent flame front velocity as the actual simulated velocity profile as shown in fig 10 (attached) figure on the right side. Is this due to meshing oR physics problem ?
Kindly help me out sir,
THANKS A LOT IN ADVANCE
face meshing, fluent meshing, meshing advice, meshing and geometry
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 19, 2023 00:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Gambit meshing problem to following geometry ahmadmln ANSYS Meshing & Geometry 2 October 21, 2014 02:49
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem dalecooper ANSYS Meshing & Geometry 0 July 19, 2013 08:04
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
