[ANSYS Meshing] Fluent: 2-way FSI. Mesh around moving cylinder |
May 21, 2018, 11:30 |
South Yorkshire
Rep Power: 8 |
I am trying to simulate the flow around and the response of a fixed cylinder interacting at a particular flow rate. Due to the characteristics of my problem, it corresponds to a 2-way FSI problem. I separated the meshing into "transient structural" for the cylinder and the fluid around it into "Fluent". In this problem, I need a very fine mesh around the cylinder to capture the generation of vortices around it (my goal at the moment is to achieve y+ =1). The problem is that every time I run the simulation I get negative cell volumes. From my understanding, a finer mesh implies a reduction of the time step to avoid the appearance of negative cell volumes. This means a prohibitively small time step to solve my case. One possible solution that I was thinking of is to create a small fluid zone of a few mm and "glued" it to the cylinder surface. A second zone with a coarser mesh that is more robust in its deformation and an outer water zone. I have no idea how to do this though xd. The above is just an idea though. I'm open to any suggestion. TLDR: How to avoid negative cell volume problem with a fine mesh around a cylinder submerged in water? Thank you |
May 25, 2018, 12:04 |
South Yorkshire
Rep Power: 8 |
I have been trying different configurations and I managed to move the boundary layer fluid zone with the cylinder movement. To do this, I selected the spring smoothing method, selected the coupled surface and then selected "Deform adjacent boundary layer with zone".
The problem I have now is that the rest of the fluid doesn't deform with the movement of the boundary layer fluid zone. I attached some images to show clearly the problem. The mesh density and geometry shown are just for testing rapidly if the mesh deforms or not. Thanks, |
ansys, fluent, fsi, negative volume cells |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
Moving Dynamic Mesh in Fluent 6.2 | R.M.Bharath Somayaji | FLUENT | 0 | January 9, 2006 20:36 |
