[ANSYS Meshing] Help creating contact regions |
May 18, 2018, 17:03 |
Rafa
Rep Power: 8 |
Hello!
I'm "learning" Ansys and was meshing when I came up with the next problem: I have two bodies, a square of 4x4 and a square 2x2 inside of the first one. It's an imported geometry, the meshing software doesn't dectect the contact regions between the solids and I want to use the opcion called "Contact sizing" to refine the mesh in the contact zone. I know I can create a contact region between the bodies but it doesn't work (probably because I don't know to use contact region opcion at all). Can someone help me? Thanks! |
May 19, 2018, 07:18 |
#2 | |
Amin
Rep Power: 15 |
I guess you're looking for the so-called conformal meshing which is important in contact regions, if so you gotta go ahead and select feature "form a new part" in design modeler, then mesh software will automaticaly recognise the contact region |
May 19, 2018, 17:37 |
Rafa
Rep Power: 8 |
Yes... I think it's the best opcion. Thanks!
ansys, contact, region |
Error The mesh file exporter does not support overlapping geometry in Contact Regions | sachinip | FLUENT | 3 | March 11, 2015 16:27 |
chtMultiRegionFoam different properties in (fluid) region(s) | volker1 | OpenFOAM Pre-Processing | 3 | February 4, 2015 07:46 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
[ICEM] Meshing Contact Surfaces | sandeep_tu | ANSYS Meshing & Geometry | 0 | October 20, 2010 15:00 |
