[Other] [SpaceClaim]Anchoring sketch curves
Old   May 17, 2018, 07:27
Default [SpaceClaim]Anchoring sketch curves
António Soares
Outbound is on a distinguished road
Greetings,
I've been enjoying learning about SpaceClaim but there are things about it that I still find infuriating.
Is there not way to fix anchor a sketch curve so that I can set the length of a straight line and have a perpendicular line merely extend its length to match it instead.
Since there are almost no sketch relations I can't seem to force certain constraints on my sketch curves.
What's the best workaround for this?
Thanks
Outbound is offline   Reply With Quote
[ICEM] Attached geometry curves niablis ANSYS Meshing & Geometry 1 October 7, 2020 06:59
[ICEM] Surface does not follow curves, ICEM yonpanman ANSYS Meshing & Geometry 1 January 6, 2017 06:29
[ICEM] Error 2D mesh - Separate curves seen as one when associating bbmorales ANSYS Meshing & Geometry 3 June 11, 2013 12:56
[ANSYS Meshing] Boolean Subtraction of 3D Curves with Circular Cross-Section from Cube? ANT ANSYS Meshing & Geometry 5 September 12, 2012 13:19
Version 7.04 : disappearing feature curves and other woes nomad STAR-CCM+ 2 September 4, 2012 22:07
