[DesignModeler] 2D Geometry Slicing
Old   May 16, 2018, 18:13
Default 2D Geometry Slicing
Ibrahim alkahla
eng1989 is on a distinguished road
I am simulating very long heat exchanger buried in ground in 2d around 200 meters.
The geometry is created. But, i face an issue in meshing with high skewness. so i tried to slice the geometry but unfortunately does not work
I appreciate if someone can help me. how i can do slicing in 2d geometry.
pictures are attached.
eng1989 is offline   Reply With Quote
Old   May 18, 2018, 13:32
amin.z's Avatar
Amin
amin.z is on a distinguished road
I got no idead why you're not using a mapped mesh, it would be much easier to generate a mesh in such a 2D geometry
amin.z is offline   Reply With Quote
Old   May 19, 2018, 06:02
Default Slicing 2D Geometry
Ibrahim alkahla
Hi Amin
Thx for your reply , since my geometry is very long , Pipe depth around 200 meter and pipe dia 30 mm, it is difficult to apply map face mesh , i tried to do it , but it dose not work, i got an advise to do a slice meshing then apply map face mesh. but the issue i do not know how i can do slicing for the geometry. also , i need to control the number of elements and node below 512k.
Can you please advise and really apprecaite your reply
Old   May 19, 2018, 07:11
amin.z's Avatar
Amin
Originally Posted by eng1989 View Post
Hi Amin
well, the dimension of your model has nothing to do with mapped meshing, all you need to do is adding pre-defined feature called face meshing in Ansys meshing and selecting your mesh. You might prefer having a 4-edge face , otherwise you'll have to deal with some extra settings. And if you wanna controll your nodes in your domain, simply use edge sizing feature.
About the slice, there are different methods, I personally prefer to have a master part (in 2D a master surface) which has overlap with other parts and simpy manage this part (slice it) using boolean>subtract.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
Extracting a non-uniform slice from a 3D geometry APSK Visualization & Post-Processing 1 October 30, 2014 16:56
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
