[ICEM] Structured to unstructured mesh problem |
Grigory
Rep Power: 8 ![]() |
Hello everyone!
I have a problem while saving my ICEM CFD mesh. When I click "Save" or just close the ICEM application (it saves before exiting) the structured mesh I've been working on automatically converts to unstructured. Is there a way to "unconvert" the mesh somehow back to the structured one or stop ICEM CFD from converting it to unstructured while saving/quitting? I hope for your help very much, because currently, ICEM is winning 7:0 in messed up projects of mine. ![]() |
Gert-Jan
Rep Power: 27 ![]() |
For which solver will you use your mesh?
Grigory
For ANSYS, but I want to save the mesh for the further corrections, etc.
Gert-Jan
I mean cfx or fluent.
But what do you mean by saving? By saving the project or exporting it to a solver (e.g. cfx or fluent)? To my best knowledge these are unstructured solvers so you can make a structured mesh, the solver uses it as an unstructured mesh anyway. If you want an export to something structured you should export to a (ancient) structured solver e.g. cfx-4 or star-cd. Good luck, Gert-Jan |
Grigory
I wanted to mention Fluent, my bad. Yes, I want to save the project (or close it) but I want to be able to come back to it later for some mesh adjustments and refinements. I know that I can convert it to unstructured before sending it to Fluent, but as far as I know I can’t convert it back to structured to correct it.
#6 | |
Sebastian Engel
Rep Power: 21 ![]() |
Hi Grigory,
In case you have a mesh but no blocking, you can find an option to resonstruct a blocking from a given mesh, if and only if it was created structuredly. Go to File> Blocking > Create from Unstruct Mesh Be warned, his feature can take quite some time to reconstruct a big mesh! But back to you original question, you could try to close your mesh(File>Mesh>close Mesh) before saving the project. Best regards, Sebastian |
icem cfd, saving, unstructured mesh |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Problem with pressure when using "empty" and unstructured mesh | andreachr | OpenFOAM Running, Solving & CFD | 0 | June 9, 2016 13:07 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
