[ANSYS Meshing] Inserting file from solid work & overlap in workbench ? |
May 8, 2018, 14:19 |
tar
when I insert a file (dimensions are about micro meter) in fluent from solidwork, in meshing part there is an error. the error is about overlapping and the message wants to repair it. there are not any overlaps in my model in solid work
. the most important point is that when I increase the dimension about millimeter, it is automatically solved. |
May 18, 2018, 13:55 |
Amin
Rep Power: 15 |
There could be different reasons,
based on what u described sounds like it's a problem with tolerance where you have the connection between your parts, I could suggest either reduce the tolerance in Ansys Meshing or directly deal with your geometry (which I'm not sure now if it could solve your problem) one solution to your geometry problem could be the idea that intentionally generating the parts with overlap and cut them in ANSYS But would suggest to go ahead first with the tolerance part |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
