[ICEM] How to improve the mesh of 3D highly twisted axial compressor blade
Old   April 18, 2018, 13:12
Default How to improve the mesh of 3D highly twisted axial compressor blade
pchoopanya is on a distinguished road
I am trying to do a 3D mesh of a single axial compressor blade, which is highly twisted and tapered from hub to tip.
However, I am not satisfied with the quality of the mesh and need your suggestion on how to improve it.
1. One thing to note is that the blade is having a large (negative) angle of attack (assuming the air is flowing from left to right, horizontally) >>> from my current meshing strategy, gives me sharp-edged elements around the leading and trailing edges. What would be a better strategy to avoid such sharp elements?
2. I managed to get a nicely mapped mesh around the blade surfaces, however, the internal elements are of low quality, especially around the leading and trailing edge. How can I improve this?
pchoopanya is offline   Reply With Quote
Old   April 18, 2018, 13:13
more photos
Old   April 18, 2018, 13:16
Here shows the bad elements (sharp -edged)
Old   April 18, 2018, 18:08
Gert-Jan
Gert-Jan will become famous soon enough
Why don't you smooth your mesh? Try Laplacian method, and quality will improve significantly.
Gert-Jan is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ANSYS Meshing] How to refine a diffuser mesh in axial and circumferential directions seperately ? ulvi90 ANSYS Meshing & Geometry 0 December 10, 2013 09:19
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
How to visualize highly distorted mesh lingdeer CFX 6 November 13, 2011 19:31
