[ANSYS Meshing] Min. orthogonal quality with zero number of elements?
Old   April 18, 2018, 02:47
Default Min. orthogonal quality with zero number of elements?
Francis Jenner T. Bernales
fjtb is on a distinguished road
Hi! While checking the orthogonal quality of my mesh, I found out that there are no elements corresponding to the minimum value of the orthogonal quality (see image below). Is this normal? And what does this imply? Thank you in advance to those who will answer
fjtb is offline   Reply With Quote
Old   April 18, 2018, 03:49
Bond Chris
bonndchris28 is on a distinguished road
Hi, based on the legend for the plot, there seems to be atleast one Pyramid element (leftmost in the plot) close to the displayed min quality. What is the quality for that element showing as?
bonndchris28 is offline   Reply With Quote
Old   April 18, 2018, 05:08
Hello! Thanks for replying. The leftmost bar (the blue one which is supposed to be a pyramid element) is actually the one with the yellow label. It's just weird to me that ANSYS Meshing is showing the "minimum ortho quality" bar yet it shows 0 element count. Or maybe there's a reason for this, which is something I don't know?
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
