[ANSYS Meshing] How to: Grid independence study for structured mesh
Old   March 30, 2018, 00:46
Question How to: Grid independence study for structured mesh in ICEM CFD
Dronzer's Avatar
Dronzer is on a distinguished road
Hi everyone,
I am trying to predict cd and cl for NACA 0012 which is a test case from Drag Prediction Workshop 6. I have constructed a structured mesh (minimum quality=0.9 and minimum angle=72) as shown in Figures (attached).
Using the above mesh I completed the simulation in Fluent with 7% and 2% errors in cd and cl.
I want to improve the above results and planning to do a grid independence study. Is there any standard way of doing it for structured mesh in ICEM?
If yes, please tell me.
Dronzer is offline   Reply With Quote
Old   March 30, 2018, 05:04
NablaDyn's Avatar
NablaDyn is on a distinguished road
A simple method is: Find a reasonable solution on a coarse grid. Refine globally, e.g. by 2x2 cell splitting (in 2D). Rerun your simulation and compare the results.
Refine further until you reach satisfying convergence.
BUT: Keep in mind which discretisation schemes you are using. Second order accuracy formally leads to 'faster' convergence when reducing discrete step sizes than first order schemes.
NablaDyn is offline   Reply With Quote
Old   March 30, 2018, 05:14
Dronzer's Avatar
Hi NablaDyn,
Thank you for your reply.
Yes, I do have an initial mesh and solution now.
Can you tell me how to refine the grid globally for a structured mesh in ICEM ?
Old   March 30, 2018, 05:26
NablaDyn's Avatar
I'm not familiar with ICEM. But I'm perfectly sure it offers such refinement tool(s) . Searching the GUI or ICEM's help pages would be the best next step.
Old   March 30, 2018, 05:54
Dronzer's Avatar
Thanks for the suggestions
I could see global sizing parameter for unstructured meshing. But I could not find such options for structured meshing.
I am quite new to ICEM so I may be wrong.
Old   March 30, 2018, 05:59
NablaDyn's Avatar
Can you apply that refinement tool or is it not available for your mesh? If so, is the resulting mesh still of quad type? If not, do you have access to the mesh generation data, i.e. where the point distributions on the lines and the surface meshes have been defined?
Old   March 30, 2018, 09:09
Dronzer's Avatar
I believe that global refinement tools are only for unstructured mesh in ICEM(as far as I know).
Yes, I do have access to the number of elements, distribution etc of edges of the blocks (as in fig).
Old   March 30, 2018, 09:42
NablaDyn's Avatar
Well, that's a good starting point. I assume the 'nodes' entry in the bottom left mask is what you are looking for. Try to adapt the number of nodes uniformly at each mesh-defining edge. As your mesh looks pretty dense I would suggest to first coarsen it, say half number of points, before going too fine.
Old   April 1, 2018, 00:37
Shawnnnn is on a distinguished road
If you use blocks to generate your mesh, you can start with corse mesh, e.g. 1 million nodes. Then you can increase the nodes to larger numbers, like 2, 4, 8, 16 million.
For 2D problem, you can double the nodes for 1 direction each time.
Compare the results to check convergence. For this case, you can compare global parameters like drag force. Or you can plot out the velocity profiles, or other variables your project is interested in, at certain location to compare. When the change is not much, the mesh can be thought as converged.
Above is my understanding for grid convergence check. Hope it help.
Shawnnnn is offline   Reply With Quote
drag and lift, grid independent study, icem 18.1, naca 0012, structured hex mesh
What is meant by Grid Independence Study? Khan FLUENT 10 July 2, 2015 23:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
grid study, important question hamid1 FLUENT 1 August 4, 2013 01:14
[ANSYS Meshing] grid study, important questions hamid1 ANSYS Meshing & Geometry 2 February 10, 2012 14:28
A doubt on grid independence study G.Balakrishnan FLUENT 4 November 21, 2000 12:05
