[ICEM] Block Topology about Twin Concentric Tunnel with Blades |
March 29, 2018, 13:26 |
Rep Power: 9 |
Hello. I'm working on simulation of tunnel flow with kind of complex geometry, shown as attached figures.
There are two layers of flow. Inner one contains 4 blades blockage. Outer one contains 6 blades blockage. I want to use O-blocks to construct hex mesh with ICEM. However, it's kind of hard to split the block in to 4 (inner, or 8) and 6 (outer, or 12) parts. Could you give me any hint to build the blocks? Any help is appreciated! I attached the figures and parasolid file here. Thanks, Shawn Tunnel Fan 1.JPG Tunnel Fan 2.JPG Tunnel Fan Flow Domain.JPG Tunnel_Fan.zip |
[ANSYS Meshing] Solid block inside a tunnel for smoke production (3D) | freddyflue | ANSYS Meshing & Geometry | 4 | December 15, 2017 16:39 |
Problem with building geometry - concentric cylinders | Rhoddwen | OpenFOAM Pre-Processing | 9 | December 17, 2014 10:02 |
Problem with geometry - concentric cylinders | Rhoddwen | OpenFOAM Running, Solving & CFD | 0 | December 15, 2014 09:22 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
