[DesignModeler] Cylinder with helical tube inside it
Old   March 28, 2018, 14:48
Default Cylinder with helical tube inside it
Anne
Anne12 is on a distinguished road
Anyone can help in designing a cylinder with helical tube inside..I dont know how to assign length and pitch to the pipe and how the extra length of pipe can be added to inlet and outlet after giving suitable number of turns to the pipe inside the cylinder..
Anne12 is offline   Reply With Quote
Old   April 1, 2018, 07:54
Joćo Vale
carbinemen is on a distinguished road
Hi. I am not sure I understand what you need. Can you post a drawing of the intended final geometry and which part of it do you need help with?
carbinemen is offline   Reply With Quote
Old   April 2, 2018, 04:28
Anne
cyl.JPG here the length pipe is given as 4.35m ,cylinder height is 0.32m and pitch is zero. I am having problem in designing the helical pipe.
Old   April 3, 2018, 05:28
Joćo Vale
To design a helical pipe, you have to sweep a cross-section around an axis of rotation. So after sketching the cross-section for your helix, you have to choose the axis of rotation. You can choose one of the standard axis (X, Y or Z) but I usually sketch a line where I want the axis of rotation to be. After that, you use the sweep feature, where the profile is the cross-section and path is the axis. Then you can select Pitch or Turns in Twist Specification. Since I usually draw my axis of rotation with height equal to the height of the helix, I can just select Turns and specify how many turns I want for that length. I also control the radius of curvature by the position of the axis. Is this how you designed your helix? I still can't understand exactly what you are asking.
About extending your inlet and outlet pipe, after generating the helix you can select the inlet or outlet face and Extrude it.
Old   April 3, 2018, 09:17
Smile
Anne
Thanks for ur help
Old   February 21, 2019, 14:45
Question
Roh
Roh is on a distinguished road
Guys,
I need to draw a helical just like the below screenshot but the second profile should not be changed(shouldn't be scaled-down). I don't know how to draw it. Any idea?
Roh is offline   Reply With Quote
ansys, cylinder, helical pipe
[GAMBIT] Boundary layer over a Helical tube surface Jammy ANSYS Meshing & Geometry 9 May 8, 2017 05:30
annulus ice melting by gained energy from hot flowing fluid inside tube Sedcfd FLUENT 0 March 29, 2017 08:00
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
[ICEM] Injector Tube into a Big Cylinder - How to mesh? Leepox ANSYS Meshing & Geometry 2 November 25, 2011 11:45
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 02:40
