[ANSYS Meshing] Moving mesh: Inflation following the rigid body? |
March 23, 2018, 07:26 |
Jakub
Rep Power: 8 |
I would like to kindly ask you to help me work out the problem, i.e. how to make it possible so that the inflation will follow a box motion udf, and also how to enforce the front side of the inflation to do layering instead of a rigid body as depicted below? Thank you very much for your help. BR, Jakub |
March 24, 2018, 09:44 |
Jakub
Rep Power: 8 |
Never mind, I worked that out.
August 15, 2019, 01:28 |
poya
Rep Power: 13 |
Hello Dear
Is there a way for non-rigid movement (deformation by user defined function)that inflation remain unchanged? |
inflation, moving mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Rigid body rotation about a moving axis | k1k | FLOW-3D | 0 | July 16, 2015 03:41 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Turbulent solver rigid body mechanics | philippose | OpenFOAM Running, Solving & CFD | 53 | July 16, 2011 14:35 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
