[ICEM] Periodic Vertices don't result in Periodic Face |
March 19, 2018, 14:51 |
Philipp Wiedemer
Rep Power: 9 |
i have the following problem, as illustrated in the picture below. The vertices highlighted by the yellow circles are periodic, as you can see by the adjacent periodic faces and the red arrows. The face between them should thus be periodic aswell, but this isn't the case. I have a suspicion but can't get behind how i can fix the issue. After i was done spliting the blocks i encountered two vertices where there should only be one. Foulishly i just merged the vertices and carried on. Maybe that's the reason for the weird behaviour, i can't get back to that state anymore though. Does anyone have a suggestion how to resolve this issue? Thank you and Greetings Philipp |
March 20, 2018, 07:58 |
Philipp Wiedemer
Rep Power: 9 |
I removed the middle blocks, and defined them again as create block from vertices and now the faces are periodic as they should be.
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[ICEM] Rotational periodic vertices change their location automatically | swm | ANSYS Meshing & Geometry | 6 | December 26, 2013 10:43 |
[ICEM] Specifying Periodic Vertices Causes Strange Problem | Josh | ANSYS Meshing & Geometry | 5 | July 19, 2011 16:09 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
