March 19, 2018, 12:15 |
Meshing for Combustor
Jahangir
Rep Power: 9 |
Hi there,
I am working on the analysis of combustion in axissymetrical 2D with swirl using ANSYS workbench 17.2. I need a very dense mesh near the inlet of the combustor, where most of the swirl and turbulence is taking place. Can someone guide me, how I can define a dense grid around the inlet and less dense mesh as I go away from the inlet. Please see the rough sketch of the objective I want to achieve. |
April 18, 2018, 12:38 |
Akram
Rep Power: 10 |
did you find a solution for you problem?
combustor, meshing 2d, swirl combustion |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
