[ANSYS Meshing] Problem with Inflation layer at corners with small angles
Old   March 14, 2018, 13:37
Question Problem with Inflation layer at corners with small angles
varun soni
varun889 is on a distinguished road
I am trying to generate a hybrid 2-d mesh for a backward facing step flow but with an angle given to the step. So, i have divided the domain into blocks and assigned the number of nodes to the rectangular blocks but relying on automatic mesh generator for mesh in the triangular region. but as i reduce the backstep angle to 30 degrees, the mesh starts to miss out elements at the corner. I have tried everything from changing the thickness, growth rate and other parameters that may effect it. I used same approach for higher angles such as 40,45 and 60 and I m fairly new to this world of CFD and would really appreciate any suggestion.
find the photos of 1) geometry, 2) mesh problem at small angle, 3) correct mesh (how it should look).
Regards,
varun
varun889 is offline   Reply With Quote
backward facing step, inflation layer, inflation layers, mesh
[ANSYS Meshing] 2D inflation layer contains triangles jones007 ANSYS Meshing & Geometry 8 May 4, 2020 09:42
Problem with entire domain comprised of split hex cells Arzed23 Main CFD Forum 1 November 8, 2016 00:01
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[ANSYS Meshing] Cut cell meshing - inflation layer Lucy13 ANSYS Meshing & Geometry 1 November 23, 2015 07:17
[snappyHexMesh] Problem in snap for wing Zephiro88 OpenFOAM Meshing & Mesh Conversion 0 July 30, 2014 13:14
