[ANSYS Meshing] SolidWorks and Share Topology |
March 6, 2018, 02:57 |
Thomas Enzinger
Rep Power: 8 |
actually I'm fighting with the SolidWorks-Interface of Ansys Workbench for an Multi-Body-CFX-Mesh. Problem: Volume bodies with a shared face (contact region is automatic detected) must have an equivalent mesh at contact face. In DesignModeler and SpaceClaim I can tell the Workbench about Share Topology and all is fine. But with an SWX-Interface, it seems to be a mission impossible. Is there an way to insert an APDL / ACT script (or something else) to transfer the information about share topology to the mesher? (Support-Ticket is open, but may be somenone else has an solution for me ) Edit: We use the SolidWorks-Interface because of parametric model is in SWX and we will setup up an parametric wb solution for many cases. |
May 21, 2018, 05:23 |
Hi Thomas,
I have the same problem as you. Did Support come back with a satisfying answer ? Best, adj |
