[ANSYS Meshing] Difficult combination of meshing!!! Tried every method
Old   March 1, 2018, 17:50
Default Difficult combination of meshing!!! Tried every method
Henry
hcmosley1 is on a distinguished road
I have a gas and air inlet with high density trying to combine the fluid domains and keep the density around the inlet. I have tried many methods any body have an idea?
I have attached photos. and one with a section view to show the skewed bad quality mesh.
hcmosley1 is offline   Reply With Quote
Old   March 1, 2018, 18:03
Default Extra infro
Henry
When I generate the mesh for the two outer cyliners (the inlet) first then generate the mesh for the larger fluid domain it is connected to, I get the mesh I was hoping for.
But does this mean I will have the generate the mesh for each part separately
Best wishes
meshing 3d
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 12:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[ANSYS Meshing] Meshing takes forever yahmed ANSYS Meshing & Geometry 5 October 30, 2015 09:44
Immersed boundary method (IBM) vs Dynamic meshing tomyangbath Main CFD Forum 5 April 17, 2009 04:02
