[TurboGrid] Diffuser passage for radial compressor in ansys turbogrid |
March 1, 2018, 04:05 |
Vasudevan K
Rep Power: 11 |
Hi
I have curve files for the blade, hub and shroud. When I extend my curve file upstream of rotor blade, an inlet is automatically created in Turbogrid V18.1, but I am not getting the same result when I do it downstream of the blade in order to get the diffuser. Also, I'm getting a message "No valid outlet mesh found, outlet is turned off" when I load my curve files. Also if someone can tell me a way to create diffuser when I'm using curve files in data import wizard in Bladegen, It will be of great help as I'm struggling with both the methods. Suggestions are welcome. |
March 1, 2018, 04:31 |
M
Rep Power: 13 |
Can you add an image of what TGrid does and what you expect it to do?
March 1, 2018, 05:42 |
Vasudevan K
Rep Power: 11 |
Thanks for the reply. I have attached two photos with highlighted regions of interest.
The image named Turbogrid shows the geometry created by Turbodgrid when I used the curve files (area marked with free form should be diffuser). But it has mentioned it along rotor passage. You can see an inlet portion created sepeartely. I extended the curves upstream of the blades and the inlet domain was created automatically. When I tried the same no separate domain was created when i tried extending the curves downstream of rotor. When i tried trimming the outlet, the extended portion of curve was not used as diffuser either (although I don't if it would) as shown in the image Turbogrid2.png So I would to know as how generally a diffuser is modeled when I model my rotor in Turbogrid. |
March 1, 2018, 06:02 |
M
Rep Power: 13 |
I am not a 100% sure, since I have only used it for axial turbomachinery yet, but I saw something similar there.
Basically, there are two ways to model the outlet one of which might give such a result. In the Mesh Data options -> Mesh Size and at the bottom, there are check boxes for Inlet and Outlet Domain. If you have "Outlet Domain" off, you are still able to model it, by manually setting outlet position (I think that is what you did?) at the Outlet Options. This I think can lead to this. If you instead check the box to include it ("Outlet Domain" on), the region could be as you expect. Then, your option to "trim outlet" refers to the area, where TGrid "ends" the blade mesh and begins an outlet mesh with a set expansion ratio, which can be edited under Mesh Data -> Outlet. I found this kind of confusing at the beginning as well, but once figured out, it is a good feature. |
March 1, 2018, 08:23 |
Vasudevan K
Rep Power: 11 |
Thanks AtoHM, I've tried what you suggested. But when I check the outlet domain box and click apply, it throws an error which says "the is no valid outlet domain to mesh. The outlet will be turned off".
I don't know why. I've also searched the internet for this error but no luck for me. |
March 1, 2018, 09:58 |
M
Rep Power: 13 |
First of all: yes this is exactly the problem I had and good news: this is going to help you get rid of it
The problem: you are giving TGrid shroud and hub contours. By using all of this data in the Outlet options (I guess you have "fully extend" active?), TGrid uses it. But, it does not know if your model actually includes an outlet or for example a veeeery long blade. So, you have to tell it which part of the contours you give belong to the blade and outlet regions respectively. I added an image of my axial geometry, also recreating your error. There "fully extend" is used in Outlet options. TGrid tries to mesh blade and outlet in one run and gives this strange twisted geometry. Additionally telling it to include the outlet, it doesnt know how to handle that, since outlet is already meshed! Now, to avoid this: go to Geometry->Outlet options. There, specify a trimming. Since you have a radial type, try a radius thats above the blade trailing edge but well below the maximum radius you gave in your contours. Let TGrid refresh the geometry. Now, since Outlet is still inactive in Mesh Data, go there and try to activate it. Should work. At the position where you trimmed the outlet, there should be a recognizeable split between blade and outlet mesh. Excuse my Paint skills. I hope it still helps to resolve your issue. |
bladegen, radial compressor, turbogrid |
How to simulate a diffuser in ansys fluent | Hello_Fluent | FLUENT | 8 | February 26, 2019 21:47 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
Ansys CFX Turbogrid, Problem with blade leading edge sitting on hub at inlet | Irondome | CFX | 9 | August 18, 2016 19:56 |
[TurboGrid] GE rotor B geometry for Ansys turbogrid | sonny | ANSYS Meshing & Geometry | 6 | August 29, 2014 21:01 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
