[DesignModeler] UGRENT HELP|| Boolean Operation Manifold Error on a file imported from solidworks |
February 15, 2018, 18:38 |
Payar Radfar
Rep Power: 8 |
Hi Guys,
I have a geometry, let's say its a pipe with a venturi after. My study is on the flow and see what speed ratio i can get with the venturi, keeping in mind that i have to have a really big domain and study the flow over and inside the "pipe". I have designed the model in SolidWorks then I tried importing it to Ansys Design Modeler. Once I draw a bigger box and try to use boolean to subtract, I get the mani-fold error. I have also read other threads on this issue such as; surface and body issues, edge to face issue. However, I cannot find the problem. I tried drawing a simple model as one part using revolve option (thickness of 10mm) and different sketches. Once it was imported, Design Modeler read as 3 parts and I can apply boolean successfully to 2 parts but there is always an error with one of the parts. Then I tried the actual model with more than 500 parts as assembly it gave the same error. I also tried different file formats. Could you please advise where I am possibly going wrong? Thank you Payar |
designmodeler, error, import, manifold, solidworks |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
