February 15, 2018, 12:56 |
Problem MESH
Crisciele
Rep Power: 8 |
I have been working on a mesh for almost 1 month and canīt find a good one. I donīt know what I have to do. I searched on youtube. I searched on manualīs user. I really donīt know. How can I do this mesh? (I took a print of the current mesh I did.) Iīm sorry about my english, Iīm from Brazil.
If someone could help me and have patience because Iīm really unskilful about icem mesh. thank you |
February 17, 2018, 10:07 |
JAck
hello guys l am trying to mesh my wing bottom skin is fine for meshing bbut up sking giving bad results l cant figure out how can you guys help me?
February 20, 2018, 07:26 |
Crisciele
Rep Power: 8 |
Ok. Thank you.
February 20, 2018, 13:07 |
Crisciele
Rep Power: 8 |
February 20, 2018, 15:05 |
Crisciele
Rep Power: 8 |
At first I got a good quality mesh, but then I exported it to the fluent and simulated it for the energy and flow. In the result the fluid isnīt flowing from the semicylinder to the bigger cylinder (it is a natural convection problem). Then I changed the geometry, to let the fluid flow into the bigger cylinder, but the mesh is not getting a good quality. I did the mesh by blocking.
If you can help me, Iīm really really thankful. |
February 20, 2018, 15:29 |
#9 |
Crisciele
Rep Power: 8 |
February 21, 2018, 06:56 |
#12 | |
Crisciele
Rep Power: 8 |
This is a part of a evacuated solar tube collector. The long pipe is half of the tube of the solar collector, where the water flows in to be heated. The bulb is part of the tank. The water flows from the tank to the long pipe, the water heats then by natural convection comes back to the tank. I think it does not have interface because it is the same fluid flowing and because there is a mass transfer between the tank and the long pipe. Is this right? because I canīt say if I know for real what means a interface (I will look for more information about this). Sorry, I'm very new to it. I cant thank you enough for everything youve done. |
February 21, 2018, 07:13 |
#14 | |
http://www.youtube.com/c/AdvancedEngineeringSolutions |
February 21, 2018, 12:42 |
#15 | |
Crisciele
Rep Power: 8 |
blocking strategy, mesh 3d, problem mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 05:27 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 11:06 |
[GAMBIT] SOFC crossflow mesh possible problem??? | epc1 | ANSYS Meshing & Geometry | 1 | February 4, 2013 02:57 |
