[DesignModeler] Internal face normal direction |
February 12, 2018, 15:38 |
Rep Power: 9 |
Hi guys,
Is there any way to 'fix' the normal direction of an internal face? I am doing a 2d axisymmetric fan simulation and am trying to do an optimisation but the fan boundary condition keeps flipping directions as the normal direction keeps flipping. From what I've read, there is a 50-50 chance of what direction will be the normal with an internal face. Thanks in advance for the help! |
February 13, 2018, 05:47 |
Baris PULAT
Rep Power: 10 |
Hey Aidan,
If you are using SpaceClaim for your geometry or if you can access it, then it is really easy. This link will help you out. http://help.spaceclaim.com/2015.0.0/...ing_Normal.htm Baris |
February 13, 2018, 07:38 |
Stuart
Rep Power: 26 |
A surface (2D) body will have a normal and in DesignModeler you can use Tools/Surface Flip to change the surface normal direction if you want to change it. I've not seen a feature in DM to "fix" the surface normal direction as why would DM change it. Are you sure this is a DM problem, as you've post in the ANSYS Meshing & Geometry forum? I assume you are using Fluent as you said a fan boundary condition, is it not the CFD application doing this and that's where the issue must be resolved?
February 14, 2018, 15:35 |
#4 | |
Rep Power: 9 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | September 18, 2024 06:52 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 09:58 |
