January 30, 2018, 05:09 |
Modify radius ICEM
Mathia
Rep Power: 9 |
Hello, I have created a stepcylinder mesh in ICEM and I would like to do a couple of simulations with different cylinder radiuses. Is there any way to modify the cylinder radius with out doing it from scratch again?
Kind regards Mathia |
January 30, 2018, 06:52 |
yes
#2 | |
It is possible. Go to transform blocking. select the blocks of cylinder ( if they are deleted recover them from VORFN). scale the blocks and while doing this select transform geometry as well ( and select the cylinder). That should get you where you need. Cheers MS |
February 3, 2018, 08:36 |
icem 16.2 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 10:43 |
Cannot update new.3dm file in ICEM based on rpl file | jimmy871013 | Mesh Generation & Pre-Processing | 1 | June 20, 2017 03:21 |
ICEM 10 mesh scale foe CFX | Korsh Mik | CFX | 2 | October 7, 2005 10:07 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
