[Workbench] Ansys 18.2 "unable to attach to geometry file" Error
Old   January 30, 2018, 00:02
Default Ansys 18.2 "unable to attach to geometry file" Error
Trevor Hicks
TrevorHicks is on a distinguished road
Hi, I'm new to Ansys, and I was hoping someone could point me in the right direction on how to solve an error i encountered. I downloaded Ansys Student 18.2 using Windows 10, and am attempting to perform a steady state thermal analysis of a rectangle, however when i open Ansys Mechanical the application crashes. I've attached a screen shot of the errors generated. I'm following a tutorial so I'm sure it's software related. Any help is greatly appreciated. I've tried reinstalling the program, and installing the program on a different computer, but no luck.
TrevorHicks is offline   Reply With Quote
Old   February 12, 2018, 05:28
Luis Fernando Bello
neutron1710 is on a distinguished road
Hey. what's up?
I have the same problem like you...
have you solved it?...
Greetings!
neutron1710 is offline   Reply With Quote
Old   February 13, 2018, 09:54
Marcin
destroy is on a distinguished road
I've got some ideas:
1) please use DesignModeler instead of the SpaceClaim
2) Check if the geometry file that you are trying to import exist
3) check if you produce the Body in geometry program - maybe you've got only surfaces
Regards
Destroy
destroy is offline   Reply With Quote
Old   February 13, 2018, 21:10
Thumbs up I've solved it, thanks so much!!!
Luis Fernando Bello
Regards
Destroy
yeah, actually the problem was that it had to be a surface...
sorry for my noob error...
anyway thanks so much for your support Destroy, you are great and kind
btw also I found more information about it on:
https://studentcommunity.ansys.com/t...ry-file-error/
it helped me to solve my problem.
18.2, ansys, error, plugins, workbench
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
