[ANSYS Meshing] Solver Pivot Warnings have Occurred |
January 29, 2018, 06:50 |
zhaque
Rep Power: 9 |
I have been stuck in a problem and cant seem to get through. I have cage like structure created by importing points from SW and then converting them to line bodies. Everything works fine except when I try to solve, I get the error "Solver pivot warnings or errors have occurred.......". I have confirmed that all lines are joined by nodes (single body is formed with the add material option) I have tried the "form new part" option in design modeler. Do I need to create joints at nodes? If yes which one? Is there any other way? |
ansys, line bodies, solver pivot warnings |
different results between serial solver and parallel solver | wlt_1985 | FLUENT | 11 | October 12, 2018 09:23 |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 06:26 |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 09:09 |
confused on messages after solver has terminated | mactech001 | CFX | 1 | April 21, 2010 17:58 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
