[ANSYS Meshing] High Mesh Skewness on Cusp Trailing Edge |
January 28, 2018, 01:07 |
Joel
Hey everyone, I've been running a quasi-2D analysis on an airfoil in CFX and for some reason I keep getting minor fluctuations in lift, drag, and moment coefficients every time a run a simulation. I think its because of the high skewness in my mesh at the cusp trailing edge. I attached a photo of the inflation layers in that area. Any idea how I can go about fixing it?
Thanks a lot! |
September 2, 2021, 03:12 |
Aideal Zohary
Rep Power: 7 |
Hi, this is an old thread. But if anyone is still interested to run a simulation on the NACA 0012, NACA 4415, FX 61-184 E420 and S1223 airfoil, please take a look at:
Numerical Investigation on the Pressure Drag of Some Low-Speed Airfoils for UAV Application. https://doi.org/10.37934/cfdl.13.2.2948 Unsteady 3-equation k omega intermittency SST was used. Good comparison with XFOIL and experimental data. Transition features also shown through cf and cp plots. Learn how I designed the mesh here: https://www.youtube.com/watch?v=qZRqBu9Ss2U |
September 5, 2021, 16:12 |
Ali
Rep Power: 5 |
hi jmcquaid
Check the following document. it is a very good resource for ansys meshing https://drahmednagib.com/CAD_2018/Le..._Meshing_2.pdf i hope it helps |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 14:53 |
[ICEM] high skewness in volume with low skewness in surface mesh | f.yn | ANSYS Meshing & Geometry | 1 | June 26, 2017 09:57 |
wing with sharp trailing edge mesh through extrusion | Hybrid | Pointwise & Gridgen | 18 | February 9, 2017 11:31 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
