[ANSYS Meshing] geometry of louvers
Old   January 24, 2018, 00:26
Post geometry of louvers
VIJITH
VIJITH is on a distinguished road
Hi
I am trying to do an analysis of airflow through louvers. Could u suggest me where to draw the geometry in ansys itself or in any other software.
Also i need to change the dimensions to mm. How could i change it in ansys or pro e
VIJITH is offline   Reply With Quote
Old   January 24, 2018, 10:44
annan
annan is on a distinguished road
You can draw the geometry using DesignModeler (DM) or SpaceClaim for instance. Both are normally available in ansys workbench.
you can define your units as mm when you draw your geometry, or when you mesh, or when you solve. could you be more specific on where exactly you want to change the dimensions ?
Hope this helps.
Good luck
annan is offline   Reply With Quote
Old   January 24, 2018, 11:38
Post regarding louver geometry
VIJITH
Sir,
I am just trying to recreate a 2D figure from a journal. I am attaching the figures along with this. The problem is there are some problems coming from when i try to draw the 2D figure in my ansys. When i almost complete the geometry, one of the louver just jumps from its position and moves to another position.
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
